streetkit
Small Block Factory 3 piece 4bbl kickdown linkage. Came off an Aspen R/T that was a factory 318 4bbl. car. Similar to the erlier linkages except that the adjustment is made down by the tranny instead of up by the carb. Will work on all small blocks except for the early 273. If you are converting your small block form a 2bbl. to a 4bbl., you will want to use this kickdown. $90 shipped to your door anywhere in the USA.
Located in CA
Located in CA
