MoparKidD-4
I finally got my TQ, Eddy Performer, and MSD-ized ELB-deleted '88 5th Ave running tonight. SO much work with the A/C compressor and emissions hardware compared to my '70 Duster, won't be doing anything like this again for a while lol. Anyway I thought it would be a better choice to run a 4-hole spacer for a spread-bore carb to keep the two plenums separated which usually gives better off-idle grunt. After getting the car started and running and initial timing set to around 12*, I noticed it was running kind of rough and smelled super rich. Even though I had modified the base gasket to open up the secondary holes to match the TQ, the secondary blades were sticking open just enough to pull fuel from the spray bars and dump it into the engine at barely above idle speed. However once I got them closed it still ran pretty rough and smelled rich; I'm familiar with ignition vs. fuel issues and this one felt like a fuel issue. So I pulled the carb off and took it apart to replace the crummy nitrophyl floats with some spare brass ones I had, thinking there was some kind of float problem. But then once the carb was back together I happened to look at the bottom of the base plate and noticed something... The ports that feed vacuum to the metering rod piston were being directly blocked by the center of the 4-hole gasket! Lesson learned: when Chrysler engineers decided to use open gaskets with ThermoQuads it was for a good reason! LOL... well that's my car-related venting for the day, I have a new Fel-Pro OEM-type gasket arriving at the parts store tomorrow afternoon so we'll see if that fixes it. I still need to finish modifying the stock 2-bbl throttle/kickdown bracket so it'll work with the TQ too, not looking forward to that since I don't have a welder uggghhhh
OH and another lesson learned, don't buy cheap "rebuilt" carbs off eBay... the top section of this carb came from one my cousin bought and ran on the 440 in his '72 Polara and it always ran like total garbage, mostly due to super worn throttle shafts. Also turns out the accelerator pump plunger had the rubber seal completely fallen off and sitting at the bottom of the well which explains why it wasn't pumping at all! Ah the joys of messing with old OEM parts... lol
