Okay while the car is running better when I take off from it still seems to sputter still like its running lean. I floored it once from 50 mph and it seems fine when I floored it. I don't think there should be any issues with the fuel system since the mechanic test the system pressure and the results was 6lbs of fuel pressure. This is the second reman'd carburetor installed. It's an 84 meaning it has a Feedback Carter BBD 2bbl. I fueled up with 89 octane today and outside temperature when driving the car was 78-82 degrees today. This is because becoming slightly frustrating.
Oh well, at least the A/C is working now. The only thing I will add that I have changed yet is the timing chain and EGR valve. Do you all think it is the one of the two. The car has approximately 92k miles on it.
