83CMXGuy
OK so I have an 83' Mirada that I took the lean burn off and replaced the carb from a 2bbl to a 4bbl with a new intake and electronic distributor.
Here is the problem when we took off the Lean burn we also took out the Charcoal filter not knowing it was connected to the fuel vent from the gas tank (canister not avail to put back in). That being said now when i go to start the car it starts just fine when it's cold. But after running it for a while and then trying to restart it, it does not want to start up, it eventually does after pumping the pedal like a madman.
So, my question is this I was told to put a filter on the line and either run the other end off of the filter to the carb or just point it down in the engine bay. Does anybody know or heard of this problem before and what was the solution? The carb is a new Edlebrock 600, so i'm not sure where to connect the line to even if i should. I really don't want all that gas smell to sit under the hood if i don't connect it somewhere.
Any help would be greatly appreciated
Brian
Brian
