Mr C
- Joined
- Apr 22, 2014
- Messages
- 408
- Reaction score
- 142
Recently my 84 Diplomat daily driver has started acting up and I am stumped as to the problem.
Details
1984 Diplomat 318/ 904 original drivetrain (stock intake/ exhaust EGR etc)
Lean Burn conversion done in Oct 14:
ECU, ballast, I had lying around (4 pin).
Swapped LB BBD with Rebuilt BBD with ported vacuum port on it.
New vacuum advance distributor.
Car has run great all winter, but has recently developed a problem (has done this twice to me now).
After driving about an hour, the car will lose power and only be able to do 60 kph. Try and give it gas and it bucks and dies. Throw it in Neutral, fires right up, put it in gear and you can gingerly accelerate to 60 kph again. It feels very "weak" and boggy. In Neutral you can floor it and it will scream- slam it into gear and it will immediately die.
Once I limped home in the driveway in park/ neutral the engine will scream if you want it to, so the problem is when it's under load.
When cold, and up until the hour point the car runs fine and gets up to speed without issues...it will bury the needle.
Engine is not overheating during this issue- all's well in that department.
I checked all vacuum lines and they're all in place- no leaks...it was getting dark, so I was unable to check the trans fluid level...I'll do that today.
I've had ECUs die, and in my experience, they just stop working. I was wondering if it was my parts stash ECU that develops some issue once hot, but I've never heard of one that "kinda works".
Any help diagnosing this "new" problem is appreciated, I need this thing operational ASAP as it's my daily wheels and I don't want to take it to a shop that probably doesn't know how to work on one of these cars anyway.
Details
