Sway Bark End Link Bushing
dkamp
Terre Haute In.
On a 77 Diplomat can anyone verify a Chrysler part number for me?
I have that the End Bushing is 3834324 and the Frame mount Bushing is 3834326
posting a Parts manual page/pages picture would also be Great!
The front sway bar end link frame mount cushion, or bushing, for the 1977 Diplomat, and other 1977 F-bodies and M-bodies, is part number 3815721 (quantity 4).
The shaft (bar) link to frame attaching package is part number 3879219.
The shaft bushings were not serviced separately from the shaft (bar) itself by Chrysler in 1977. A replacement bushing was made available for later M-bodies as part number 4014035.
The following images show the pages from the 1977 parts catalog with the diagram and parts information:
Thank you for the Info !
I tried to verify where I got my Mopar number but now do not know.
What is a recommended modern part to use for the End Link Bushings?
Following are aftermarket part numbers. Double check contents and application before ordering as some older numbers may have changed or been reassigned. Some older companies/numbers are discontinued, but might still be found. My preference would be NOS Chrysler, followed by older Moog, TRW, Sealed Power, or McQuay-Norris. For modern availability, Moog might not be a good choice. Mevotech is likely the safest bet.
Following are aftermarket replacement shaft bushings for part number 3815721. These are a kit package with bushing and hardware.
  • Mevotech MK7087 or GK7087
  • Dorman 541637 or 541-637
  • Moog K7304 (bushings, bolt, and washers)
  • Mevotech MK7304 (bushings, bolt, and washers)
  • Delphi TC5052
  • TRW JTS754
The later shaft (bar) link to frame attaching package, Chrysler part number 4106161, could be used in place of 3879219. It can still be found on ebay, and possibly other NOS sources. Following are aftermarket replacements. Some kits include the 4014035 shaft bushing as well.
  • Moog K7092 (includes shaft bushing)
  • Moog K7304 (bushings, bolt, and washers also used for end link)
  • Mevotech MK7092 (includes shaft bushing)
  • Mevotech MK7304 (bushings, bolt, and washers also used for end link)
  • Perfect Circle 265-2047
  • NAPA 265-2047
  • Sealed Power 809-18113
  • TRW 18113
  • McQuay-Norris FA1206 (includes shaft bushing)
  • Raybestos 5451116
Following are aftermarket replacements shaft bushings only for part number 4014035.
  • TRW HB1428K
  • Sealed Power 816-1422
  • McQuay-Norris FA1201
  • ACDelco 45G0604 (may contain frame link bushings/hardware)
  • Perfect Circle 265-2104 (may contain frame link bushings/hardware)
  • NAPA 265-2104 (may contain frame link bushings/hardware)
  • Raybestos 550-1104
End link- whatever your parts source has. They are alas common as dirt and pretty cheap.
