Tech question on a 318 roller block.
chmirada
Worcester, Ma.
I wanted to find out if you guys or someone would know what the deck height (piston top at tdc to deck) is on a 318 non magnum roller block?
MiradaMegacab
Long Island NY
Thats deck clearance.
Quench height = Deck height + Head gasket compressed thickness.
Deck height is 9.6"
Im guessing the pistons are around .060 down in the hole
MiradaMegacab
Long Island NY
What's up? Whatcha trying to do?
Compression height is the distance from the center of the wrist pin to the top of the piston.
Thats a nice Mirada in your avatar
MiradaMegacab
Long Island NY
They vary from the factory.
Even deck heights vary from the 9.6
Best bet is to pull the heads and measure.
a 3.31 stroke with a 9.6 deck height will need a 1.82 comp height piston to be at zero deck
