The Drive Shaft Question Again Long roof Wagon owners.
PLY478
Central Wisconsin
That is the length? Where are you measuring from?
1979 Aspen Station Wagon 360/727 with an 8.25" rear.
Thanks
PLY478
To help out, body “H and N” are F-bodies and “F and G” are M-bodies
On both, there is a 2-door length and a 4-door/station wagon length (roughly about four inch difference).
The A727 propeller shaft is shorter than any other transmission type Chrysler used in either M or F-body (and A904, A833 and A230 used the same, longer shaft), which is about four inch difference.
The 7¼” differential uses a longer propeller shaft than the 8¼” differential does, which is about 1½ inch difference.
The “45's” are station wagons. All station wagons were meant to come with 8¼” differentials (not all came that way due to supply issues, but they were “meant” to).
According to this chart (below), a 1979 HNFG 45 (station wagon or 4-door) with A727 (and 8¼“) should be 48.60 inch from center of U-joint to center of U-joint.
All factory propeller shafts for that year (or any FMJ) will be using 7260 U-joints.
If you are having a propeller shaft made for this car, this would be a perfect time to upgrade to 7290 (or stronger) U-joints which might be advisable if car is going to make any (more than stock) power.
  • 79 PM pg 16-5.pdf
This is side by side comparison of the 3 different lengths of 4 door automatic drive shafts i have. From long to short,
7 1/4-904
8 1/4-904
8 1/4-727
Along with the larger u-joints, highly recommend a differential pinion yoke that uses u-bolts instead of 2 straps and valve cover bolts. The valve cover bolt thing is something Denny (Denny's Driveshafts) said to me when I was ordering my shaft and yokes way back when.
A person can always take a old (but not bent) propeller shaft to a driveshaft shop and get it cut down.
It is a lot easier to cut a shaft down . . . than it is to make it longer.
