Locomotion
All items used unless noted otherwise.
1) INNOVA 3568 Digital timing light. Like new, only used few times. $50.00 (***SALE PENDING***)
2) Mopar Performance 1-100 lbs 2 5/16" mechanical oil pressure gauge. Set up with extension & adapter for oil pressure feed at the back of the block. - $40.00
3) Milwaukee 48-89-5680 18 piece titanium coated drill bit set (NEW) - $20.00 (***SALE PENDING***)
4) Mancini MRE4286800 Oil Pump Priming rod/shaft - $10.00 (***SOLD***)
5) CargoPal/PitPal spray can holder - 2 can capacity. - $10.00
6) CargoPal/PitPal 229 Spark Plug Hoder - $10.00
7) Summit G-1015 Engine Lift Plate. Requires your compatible Grade 8 hardware. - $7.00 (***SOLD***)
8) Performance Tool W80575 Piston Ring Installer (NEW) - $5.00
9) Performance Tool W80575 Piston Ring Installer w/adjustable stop (USED) - $5.00 (***SALE PENDING***)
10) (Similar to Summit SUM-906800?) Valve Spring Compressor (light duty) - $10.00
11) Comp Cams? Crankshaft Turning Nut - $10.00 (***SALE PENDING***)
12) Engine Galley Brush Kit Assorted sizes, some duplicates and bore sized brush included but not pictured. - $20.00
13) Craftsman 9 555271 Flaring Tool Kit plus tube bending wrench. - $20.00
14) Maasdam 144S-6 Come-Along - 2,000 lb 12' max w/15:1 leverage. Has some blemishes on finished surfaces from Florida humidity but only used a few times & in VG condition. - $45.00
15) Maasdam 144SB-6 Come-Along - 4,000 lb 6' max w/30:1 leverage. Has some blemishes on finished surfaces from Florida humidity but only used a few times & in VG condition. - $45.00
16) KingChain 153350 Snatch Block Pulley - 1 ton NEW (without hook latch) - $30.00
All prices + shipping from Florida 32117
Sorry, no PayPal.
Sorry, no PayPal.
