WANTED TRANS - damper weight insulator
Hi Everyone,
Given the part(s) in question, at this point in time this is a bit of a 'needle in a haystack' situation, so that's not lost on me.
Having said that, I am NOT (necessairly) looking for like-new/NOS pieces here, rather I would be happy with anything that still has the overall shape of the insulator bushing so that I can go shopping for a replacement one (or something close to it) given that I actually have this part in my hand.
OK, so what I'm looking for are the highlighted items in the attachment.
Let me know if you have anything...I don't care how dirty, rubber all cracked, or squashed this thing may be either!
Thanks!
I think I may have them on one of the cores in my garage. Like 80% certain.
Will check when I get home before I head inside for the night.
Honestly if you have the weight, I don’t think it would be hard to cast your own bushings at home and experiment with silicone and urethane compounds for the best ride quality to your taste.
Honestly if you have the weight, I don’t think it would be hard at to cast your own bushings at home and experiment with silicone and urethane compounds for to get the best ride quality to your taste.
THANK YOU (intentional uppercase to emphasize my appreciation)!
What I have right now is a sway bar end-link rubber bushing that happens to be the right size and has that 'top hat' on it's end. What I did not know, or could not visualize w/o seeing one, is how this mounted in/between the weight itself and the trans tailshaft. Now I think I understand!!!
Good stuff, I know where to go next with this. Thank you again!
I’ll take it to work tomorrow and slap a caliper on it give you proper dimensions. Happy to help.
