WANTED Transmission line bracket
88_AHB
West coast
Hey all,
Looking for the bracket that holds the transmission cooler lines at the front of the engine. It utilizes 2 bolt holes on the front of the block (318) beneath the power steering pump. I dont have it so I cant provide a picture for reference, I'll try to search the interwebs for a pic. Thanks
I have quite a few different ones, may be able to help if you can find a ref pic
I'll see if I can find a pic of one, do you have them easily available to take a few pics?
These were taken from my ’88 Parts Manual (I assume this is for your ’88 AHB).
I doubt I have what you need (other than the above pictures).
Now does the first one on top just hold one line? Or does it need another clamp with the bolt? I'll use whatever that'll work,I did buy new trans lines that are in there now. But I think they're for a A body with a 904. So far they've worked well,I reused the rear line holder that mounts to the back of the trans.Just wanted to get the front a little more secure.I already went and used some heat wrap on these lines since the get right next to the headers.
The red box is for one line (passenger side). The blue and green boxes (both drivers’ side) are for two lines. Basically, both lines straddle the harmonic balancer on a factory system for '88.
I can take pictures of my ’86 – if that would be helpful.
Now the A-body lines do not use rubber hoses and both lines go straight past the engine, then turn alongside the radiator.
The “hose type” lines (like what your ’88 did use) the passenger-side line goes behind the balancer then forward several inches. There would not be a passenger-side attachment to the engine when using the '73 A-body lines.
These are pictures of my ’77 (which will look similar but “flipped” from your lines). For whatever reason, Chrysler changed the transmission cooler lines every couple of years or so, to keep the techs and part guys hopping, I guess. My ’77 has the transmission cooler lines running down the passenger side of the engine (as shown).
There will be a bracket on the front of engine that will look something like the item in the blue box on my '77.
Yours will look either close to of that in the blue box (if you still have those parts available).
Thanks Bud, I’ll have to crawl under it and check. Both of my lines run on the driver side and I took a few inches off of the front lines. I re-flared them and added hose to the fittings going to the radiator. I’ve heard of people having issues with the lines(cracking) being totally rigid.
Thanks Mopar, I think one of those should work fine.
The reason they crack is one end is rigid (radiator) and other end moves (transmission. Cracking is not a common thing – but it can happen, as well as lines rubbing things (like engine mounts, etc.).
The best thing on rigid lines is to make sure lines are not close to touching anything except for the support brackets/clips as well as each other. If a person does that, then in most cases you will be trouble free.
The things I like about rigid lines is they seldom leak fluid – but a person HAS TO USE TWO WRENCHES (one is for backup on the brass fitting) or YOU WILL HAVE problems removing or installing the line nuts. If you use both wrenches when tightening/loosing and check every so often to make sure the lines are not rubbing anything – then you shouldn’t experience problems the lifetime of the car.
The rubber hose design (’80-89) rarely see line cracking problems (I don’t think I’ve seen one vs. hundreds of the rigid line cracks) – but still have rub-through problems. That said, the rubber hose portion do tend to leak, and they DO LEAK often. When in lock-up mode, the line pressure is just too great for rubber to hold back (100+ PSI).
If I had to install a cooler line (from nothing), I would go rigid (just like you are doing). Just make sure the lines are not rubbing anything and you should be good.
Note: the lines for both types use the same material. Just the hoses and different fittings on the radiator are the only difference.
