TUBULAR FRONT SWAAY
CM360
I'll need to increase the front sway bar on my 81 Diplomat. Moving from /6 to SB. Seen comments about FF backorder issues. Any tubular sway bars available? THX
There were two factory sizes available: 11/16" for civilian and 11/8" for fleet models. You'd be fine with the fleet model. Aftermarket bars are crazy expensive, but Adco might still jave something available.
M_Body_Coupe
Windsor, ON, Canada
Do not confuse the swaybar with torsion bar.
The torsion bar (T-bar) is the L shaped thing, while the swaybar is usually a sort of expanded C shape (heck, not sure what else to better compare it to).
Anyways, the FF backorder conversation was about the T-bar, or the fact that they are bringing it back.
I have a extra front F/M/J sway bar in the garage. Think it came of a AHB car, would have to measure and check. I could part with it if it helps you out.
CM360
Yes. I'm in PA. Shipping is nuts for everything.
AMC Diplomat
NY
Well sometimes you gotta go far to get what you want for one of these cars. I went to Massachusetts for a set of seats and door cards. It's either that or let a project languish. That craigslist link I posted is still up so maybe that sway bar is still available
