Tuff Wheel substitue's
I recall a thread on aftermarket Tuff wheels from a bit ago. I was perusing the Summit site and found the Grant wheel has dual bolt pattern and looks the closest to an original BUT, apparently the quality is crap or even worse, from reading the reviews.
I did find GT Performance makes one and is also dual pattern. The leather looks slightly different than original but sounds like it's much better quality than the Grant.
Also, the horn button comes with the GT wheel but is also sold separate. It looks exactly like an original and is a direct replacement for an original on a factory Tuff wheel.
Just for FYI anyways.
GT Performance 37-5265 GT Performance GT-3 Retro Tuff Design Steering Wheels | Summit Racing
GT Performance 21-1700
Aspen360
Lehigh Valley Pa
I bought the Grant from summit last month. The only reason I used grant was that it’s a more shallow profile than original since I have tilt column. It came with the horn button. Installed easily.
brotherGood
Urbana OH
I went with the Grant, and had one heck of a time with the shifter (tight against the wheel)
I ended up (with the help of another member) sourcing the "double bend" shifter which solved my issue.
DCAspen
ct.
You need the steering column can the wheel bolts on to.
