SuicideRider
In need of the turn signal, wiper, cruise control lever. 86 dodge diplomat se.
Thanks
Thanks
Thank you so very much sir. You are an invaluable source of information. You gave me everything I need to know.FYI, the cruise switch slides over the turn signal stalk - so not part of the turn signal/wiper switch. Also the turn signal switch is a different part from the wiper switch & stalk.
Confusing, yes.
For '86 Diplomat the (new) part numbers will be:
Turn Signal Switch 4221682 (without tilt steering) or 4221485 (with tilt steering)
Wiper Switch (with stalk) 4221897 (without intermittent wiper, without tilt steering), 4221899 (with intermittent wiper, without tilt steering), or 4221903 (with tilt steering)
Cruise Switch 4342209
Cover (plastic cover over turn signal arm, without cruise 4293911
Hopefully this helps you on what you are looking for.
