Vacuum Lines
ls_bcrr29
New Member
California
Hello,
I am in the process of getting my grandfather's car back on the road. Its a 79 Plymouth Volare. So far I replaced front calipers they were seized did transmission service adjusted the bands and throttle lever adjustment. Replaced cap rotor plugs and wires, oil change. The car hadn’t been touched since 2010, I am trying to figure out vacuum lines and some plugs, they aren't connected and I don't know where they go. Thanks for any help.
Maybe your hood was replaced at some point? That's one sticker you can hardly peel off, they're on there.
Was this a LeanBurn car that was converted to a standard electronic ignition?
I ask b/c in that one photo you are holding a 10-pin plug that very much looks like harness plug for the LB computer, w/o which the car won't run.
So does the car run now, or it hasn't even been started since it got parked?
