For "most years" All station wagons, Police cars and cars with “some” towing packages are supposed to come with 5-leaf rear springs.
Some exceptions exist – either by accident or by part shortage at the time of build.
I only count 4-leaves, plus an aftermarket helper spring, on yours.
The aftermarket helper spring can be unbolted and reused on your existing car – if U-bolts are still good. Personally, I wouldn’t re-use the U-bolts – for too much is riding on them (literally).
5-leaf springs also have a different lower Iso-Clamp part – to accommodate the taller spring.
These pictures were taken from my ‘77 Wagon (with 41k miles) earlier this evening. The pictures were taken from right rear corner of car, first picture from ahead of R/R tire and remaining pictures taken from behind the R/R tire.
I modified one of your pictures. The lower half of the Iso-Clamp is a (no, the) weak link on our cars, The yellow line shows you the warpage you have on your existing lower clamp and the blue circle shows where bolt holes tear out on. The red arrow shows where the lower clamp is different between 4-leaf and 5-leaf springs. Other than the spring and that lower clamp (U-shaped part) – there is no other difference between the 4 to 5-leaf spring setups.
Personally, I would get either get some older shock plates or aftermarket shock plates and do away with those Iso-clamps.
Doing so will raise rear of car about ½”, you will be rid of that problem area, it will be stronger and car will ride much better.
Either way, you can use that helper spring – if wanted.
If it was my car, I would remove your old differential with both (old) leaf springs and tires still attached to it. Roll old differential out from under your car. Then roll new differential back under car with springs attached (but not tight). So much easier and faster than other methods I have done.
Also, I would get one (of the two sets) set of springs re-arched, before hand and not mess with the helper springs.
Note: the driveshaft is shorter – if you are planning on replacing your existing 7¼” differential with the 8¼” version.
Also, you might have a gear ratio difference between new and old differential – so speedometer gear might be different,
If still available, I would grab the speedometer gear and driveshaft from that donor wagon, if at all possible.
