Washer bottle grommet
AL_Brad
Logan Martin Lake
82 Imperial
Does anyone have a good PN for the rubber grommet that seals the pump to the bottom of the windshield washer reservoir? Mine appears to have been leaking for quite some time.
dm330
Salem, OH
If they use the same part as the Fifth Avenues, Mopar part number 4762319 will work. I needed a new pump and the grommet was included. Mopar Parts Giant had some leftover new ones in stock, still in Chrysler Corporation packages.
AL_Brad
Logan Martin Lake
Thank you both. Is that the number you found Aspen? If so, I'll try that. NHA as they said in the Air Force... next higher assy.
Update - found on eBay for $20 and purchased. What came up on amazon had the plug connectors on the opposite (under the tank) side... so definitely look at those pics!
Thanks Again.
