krytellan
- Joined
- Mar 18, 2011
- Messages
- 30
- Reaction score
- 0
This has been driving me a bit nuts so I'm hoping someone might have had this experience.
I realized it during the late winter when I was installing my stereo cables beneath the passenger carpet. There was a shallow ice block in the front passenger floor pan. At that time, given the season, I drilled 2 small drain holes in that vicinity until I could get to the root of the issue.
Of course, in my area, we went from winter to 3 months of rain, rain, rain. My latest assessment revealed that the passenger floor was wet from dash to back seat floor. And yes, it's water.
In trying to get to the source of the leak I'm at a loss. I can't tell where it originates. My gut tells me that it is the body portion in the area of the front door hinges, but nothing there seems any different that the driver side door, which remains dry. In order for the water to get inside the door frames, I have to believe that the doors are not likely to be the culprit, but rather a weak spot in the main body.
The seam that extends from the lower passenger side of the windshield into the hood compartment seems a bit dry-rotted, and can't tell if someone has done some aftermarket sealing there before. Is this area the obvious culprit or do I need to be looking down the hinge line of the frame.
ANY guidance here would be most appreciated. Murphy is uncomfortable!
