Window parts numbers
BudW -
Do you have the parts numbers for the window scraper felts (cat whiskers)?
I'm looking for the generic rubber replacements and realized that the scraper felts have started falling apart (literally).
Thanks,
Bekasu
According to my ’87 (and ’84) FPM (Factory Parts Manual) – the inner window felts do not appear to be available separately from Chrysler (only come as a door panel assembly).
I’m fairly sure a person can get both inners and outers aftermarket . . . I would think.
Page pictures of the outer door glass seals/runs
A lot of these parts "appear" to still be available from Chrysler:
#7 4130712 FRT DR BELT OTR RT $21.25 (R/F Door Glass outer lower seal)
#7 4130713 FRT DR BELT OTR RT $21.25 (L/F)
#8 3875422 ASSY-RR DR WDO BELT RT $11.50 (R/R Door Glass outer lower seal)
#8 3875423 ASSY-RR DR WDO BELT LT $14.25 (L/R)
#10 4198637 FRT DR GLASS (front run channel) $114.00 (Left and Rights are the same)
#11 4198638 RR DR GLASS (rear run channel) - Superseded to 4198637 (cut to fit) Left and Rights are the same
Bud,
I owe you big time...
I'm going to order generics or something that looks like it will work and start that door rehab.
Thanks kiddo,
Bekasu
Can anyone comment on the dimensions (width measurement) for the window run channels on the fifth ave? What do i need to look for when ordering a generic? What is the difference between beaded and non-beaded and which do I have? Also, is there something that i can apply to my existing (but hardening) wipes (cat whiskers) that will help preserve them?
