My imp
I am replacing the Holley 4bbl. with a TQ. I have the linkage from an '83 318 4 bbl., 727 trans.. I am missing the piece that goes from the carb to the bellcrank. Does anyone have this piece? The Holley was installed by bending the manifold bracket to fit the cables & linkage. All (3) were binding. With the 318-4 manifold bracket installed, the kickdown linkage points right where the throttle cable goes. The cruise cable is fine, as is the throttle cable. The car shifted fine with the Holley on, so the kickdown was working fine. If needed I could convert to cable, however I'd like to keep it stock. Thanks, Larry
