I had a question asked me about the police engine oil coolers – that spray oil onto the timing chain.
Here is a picture of the system. This is from my ‘77 and '87 parts manual – sense the pictures make a bit more sense when looking at them, than pictures do (or to me, anyway).
1977 F/M-body
1977 B-body (for reference)
1987 M-body
The oil coming from the oil cooler travel via a hose, then to a short piece of pipe. The pipe then connects to a hollow bolt. This bolt replaces one of the fuel pump mounting bolts – and looks really odd. Chrysler calls this hollow bolt, a “nut” for some reason. Because this hollow bolt does hold on the fuel pump – it is fairly easy for it to break when installing a fuel pump.
Small blocks use this hollow bolt (nut) in the rear bolt hole of fuel pump. Big blocks use the front bolt hole.
The problem is the hollow bolt has a tendency to break and very hard to find and has been out of production by Chrysler sense about 1990 (or so).
In my garage, somewhere, I have a mostly complete police engine oil cooler setup (and part of another),
less the hollow bolt. Once I figure out how to make replacement bolts – I’ll install a cooler setup on both cars.
If someone would make some new bolts – I’d buy 20 right away (only I don’t have any bolt parts to use as a pattern).
My ’77 parts manual show the fuel pump bolt (called a Nut, Fuel Pump) to be part # 4071712
My ’87 part manual shows it to be # 6031741 (called a Screw, Fuel Pump, in this book)
Both part numbers have long been discontinued.
