Your steering column might bind. The engine will be higher and the trans bell housing may hit the firewall. The fan my hit the shroud on the radiator, just the name a few things that com to mind.
You can get new poly ones also. You can't totally do away with them.
Just curious, what are you trying to do?Is there anyway to not use the K member Iso pucks? FFI has a aluminum kit but can't they just be eliminated altogether or will the geometry be affected?
Nope. Didn't have them, nor did Just Suspension.Try Polybushings.com
Thanks, that's all I needed.View attachment 4364Firm Feel is 1 5/16 tall
