Worth it to fix?
moparhead
Arizona
Got burned by ‘it ran when pulled’! I’ve had cylinders sleeved due to rust, but never one that’s been windowed. This is a 71 340 block. Has anyone here successfully sleeved and raced a cylinder that looked like this?
Yikes. Any particular reason to run a 340? Class racing? Going to be a lot cheaper to grab a 360 LA or Magnum that doesn't have a hole in the bore vs fixing that 340. Should be able to get a block for $200.
moparhead
Arizona
Yeah it’s scary looking to me. The 340 motor in and of itself has some nostalgia to it. The last time I had a sleeve done it was like $80 IIRC. I have some 318s, 340s and 360s but I’d hate to toss a 340 as junk if it wasn’t.
My only concern would be price. If a machine shop says all it needs is a sleeve, then I wouldn't worry about it.
I see three cracks running to the bottom of the cylinder, looks risky to me, if you sleeve it I would expect problems with water in oil. I see a junk block.
moparhead
Arizona
Im tempted to try to weld the cracks and then have it sleeved. I’m gonna take it to the machine shop and see what they say. Will report back
