318 Aspen with magnum heads.
jed_laski
Poland, Europe
Hello! I am looking to get more horsepower from my 318 1977. The engine itself runs pretty well. I have currently put a pertronix 3 full set with chineese airgap and edelbrock 1406 600cfm wich is a little too much for the engine. What went with it is a lokar style cable and throttle and throttle plate spring set. The combo works very well, i tested it on numerous trips, amateur races and it really boosted the car from stock 2barrel configuration.
FIrst of all I have to change timing set, and it would be a shame not to replace camshaft and what goes with it a valvetrain.
Now im looking to get something more from the motor, maybe boost compression? What i have in stock is a set of 5.2 magnum heads from grand cherokee wich i could upgrade. I got also a bare block and a bit rusty crankshaft from it. What im looking for is a recipe for a nice choppy sounding cam that will be able to burn rubber. Now the car is quicker but it hardly burns any rubber on dry pavement. From what I know i need other kind of pushrods like magnum has with a hole inside. So any advice what to choose will be greatly appreciated! I am looking to get best bamg for a buck for my heads without swapping entire engine. I am capable of spending some money on speed parts, but I dont want to swap entire engine. The car has a 904, a factory suregrip lsd wich i found out is capable of handling 300hp, a factory power steering and a fake X pipe.
There are a number of videos on Youtube on how to make power with a 318, even from well known sources like Power Nation. Just have to do a search on Youtube. Also, Hot Rod Magazine did a 318 hop up video; article may still be on their web site. Those Magnum heads are a really good start (if they are cracked (a known Magnum head issue), get them checked), helping fix a lot of the LA series engine issues (breathing and small valve size, as well as a partial solution to the low compression issues (to get really good compression, you are going to need new pistons)).
I put magnum heads on my 318, with a summit 6900 cam, headers, Summit (Holley) 600 cfm carb and it was night and day difference. Down the line I also swapped in 3.55s and a sure grip into my 8.25, and it also needed a bit more converter, but it was rowdy compared to the stock AHB I started with.
The magnum heads also don't allow too much on the cam in factory form, due to springs (i believe guides as well, but could be wrong), so the 6900 was pretty close to what I could do without changing all of that.
What rear axle? If it's a 7/14 it won't handle 300hp, not that you'd get there anyway with a head swap.
What's the rest of the engine like? It might be cheaper and less work to swap something else into it unless it's low miles and well maintained.
Sticking point of swapping in a 360 Magnum (for example) is, they haven't been made for 22 years. Probably 95% of the trucks that had one are loooong gone, and what's left is worn out junk and needs completely overhauled before use. Multiply all that by a factor of 10, being the OP is in Poland. Just saying.........
We're going to need a little more information. Others have already asked gear, axle, etc... Add budget and import taxes to that list. We'll try and get you a plan that takes that into account.
I will add that a 318 turning tires off of the line is going to involve a fair amount of gear and a higher stall. Your motor will be living higher in the RPM band. Something to think about from a drivability point of view.
At the same time that could be about the same condition this 47 year old 318 is in.
As they say you start putting new parts on an old engine or trying to get more power out of it and that's when the weakest links start showing up so it would suck to put that much work into into it and not get much if anything out of it or cause some other issues.
Czesc, jak sie masz??? LOL
OK, the guys pretty much covered it all, we need to know a lot more about the shape of your 'as-is' combination, meaning: how good has the engine held up? Do you happen to know the cranking PSI right now? Have you done a leak-down test? what rear-end ratio are you running, what stall speed? etc....
Along all that, we probably need a better definition of what your actual TARGET is!
Here is why I say that: "...Now the car is quicker but it hardly burns any rubber on dry pavement...", OK, so do you want something that has that street "showmanship" ability (thus smokey burnouts), or do you want it to sound mean (that lumpy cam sound), or do you want the motor overall to increase hp and you hope that nets you all of the above?
I will say the following:
1) TORQUE
- you could focus on maximing the torque the 318 can produce, which would mean a short/er duration cam (as compared to high-RPM stuff)
- this would most likely work w/o changing too many things (parts wise, thus smaller cost)
- but this will not get you a motor that just wants to rev high and feels like the power just keeps on coming and coming
- in other words, you can build torque, but that engine will stop climbing RPM by the time you hit 5K, it will nose over, done, finished, koniec!!!
2) HP
- sort of the opposite of TORQUE (in general), although if you match all the right parts and appropriately build the motor the torque will be there as well but with the shift to a higher PRM powerband
- this is costly to do though because to make HP you normally need to bring in the high-RPM stuff, that means larger cam, higher compression ratio, parts that are either lighter, or more durable, so costs go up
- the fuel you use will require higher octane rating, again, more expense
- the thing here is that this approach is no longer JUST about the engine, you really need to look at your drivetrain as well, so think about higher stall converter, more aggressive gearing, etc., again, costs!
3) SOUND
- plenty of speciality cams out there offer that nasty 'big cam' sound while not necessairly requiring all the crazy parts and the spend associated with it
- keep in mind, this approach will not get you the BEST torque, nor the MOST hp, rather it focuses on getting you that "too hairy to run on the street" feel
- nothing wrong with this approach, but know your limitations as this is more about the 'show' factor
My advice, figure out what you are aiming to achieve and only then talk about specific parts, be it the Magnum heads, or pulling the motor and replacing it with a higher displacement altogether (318 => 360 is a night & day difference, 360 => 408 provides overabundance to torque and power, etc.).
Thanks for all the replies! It seems that I got to do some more reaserch for now. Cześć M_Body_Coupe :)
I did some reaserch and also took my magnum heads to machine shop to check if they are in good condition to work on. I decided to use a long tubes Hooker 5901HKR. New valve train, double roller chain, springs and go with summit 6901 cam wich a friend of mine has on his shelf. I belive its going to wake the car up a bit and not to mess the rear end.
First thing is that i need to use magnum style starter in order to put headers.
I checked numerous pages and I cannot figure out if that Jeep ZJ starter will fit my 318 LA +904 instead of Ram starter. I checked the rockauto for numbers and they are different. From what i can tell they also seem a little different but thw guy who sells locally claims he put a jeep starter on his dodge ram. So it works only Jeep to Ram truck and no go for LA? The jeep starters are plenty while locally i can have toasted one from dodge pickup.
I believe Jeep was on the other side, IIRC. I snagged mine from a Dakota in a wrecking yard here..but I understand that's not quite as easy based on where your location shows.
I would think though if Jeep starters work for Rams, then they should work for an LA block. Mine bolted up the same, I just had to elongate out one of the wire terminals on the factory wiring..but not even enough to need a new end.
The V6/V8 starters on all Dodge trucks and vans will work. I don't know if the Jeep starters will swap as BrotherGood stated they're on the passenger side. It's possible the starters are in fact the same and just mount upside down.
I suppose a viable check would be the look up replacement part# on a site like RockAuto for both of these and compare if they match?
If YES, than the answer is: YUP, same started just mounted upside down like Duke pointed out!
I installed recently that Dodge Ram design starter. Wow! This works really good!d
From other things i decided to go with summit 6900 camshaft, MAHLE lifters MAH-2131679, Summit hollow pushrods SUM-1457650. And i hit the wall since i have a stock magnum rockers but wanted to upgrade to Harland Sharps 1.6 - and the question is can i run them since they are roller design?
...And i hit the wall since i have a stock magnum rockers but wanted to upgrade to Harland Sharps 1.6 - and the question is can i run them since they are roller design?
So HS stuff is good, but pricey. Why not look at some alternatives instead?
For example ProForm has 1.6 ratio rockers, bronze bushed (this is nice).
If you are going to stick with the HS stuff here are a few notes worth mentioning given my experience with their rockers on the W2 build:
1) I moved to pushrod oiling, which means that I needed to control the amount of oil the factory feed was going to provide - and I did that with adjustable orifice plug that's actually mounted into the oil passage in the head, for you, given that you are moving to Magnum heads that should not be an issue as the head will block off the oil passage feed hole that's located in the deck
2) my w2 rockers do NOT have spring splash oiling, I wasn't happy about that, I would prefer to have some spring cooling taking place, but as I discussed my concerns with the HS guys they were not concerned about this stating that they have sold hundreds of these setups and never heard of an issue, so I ran as-is (no oiling), just one season so far so there is not much of a comparison I can provide
3) the w2 rockers also have the roller bearing fulcrum, this is not a problem, in fact it can be said to be the better approach as the friction is certainly lower, however this is a race-level impact at best and for folks running these things on the street I'm not certainly that 'lower-friction' is worth much, if anything I've heard people say that the roller bearing stuff will possibly get beat up on the street faster than a bronze bushed rocker arm...so yeah...go figure...
What I would suggest is that you put some money towards making sure the valvetrain geometry is correct. Take a look here (B3 Racing Engines LLC - Performance Engine Building and Mopar Valvetrains), check out the series of articles he's done. I've got the original research papers that were published on this some time ago so if you are curious I can probably upload them (PDFs).
BTW: I did buy Mike's adjustment kit for my setup, geometry was corrected although it did cause me to loose a little lift on the cam.
Hi again! Thanks for all the replies. I was absent for a while but i was busy with work, holiday trip and cars. I also had to take care of my fathers 94 ford explorer.
I ordered Summit 6901 Cam, 16982-16 Trickflow springs and Summit 1457650 Pushrods for it. Im going to use factory rocker arms as i reaserched they do a pretty good job unless extremely stressed. Im.going to use Felpro 540SD head gasket wich is 0.050 thick. The heads are done and assembled with new stuff on it.
I tore down the rest engine partially and it looks like I need a new camshaft bearings. The middle of the 2nd bearing is flaked, there is also noticeable wear under the thumb on the others so i dont want to put a new cam on weak bearings as it is accident waiting to happen. The cylinder wall where piston rings move up and down is also worn wich i can see by colour on the wall and feel slight groove. There is no scratches or crevices. All thoose signs tell me that circular shape is now a oval inside cylinder wall but i have to measure it first. Im also going to check the crankshaft and its bearings to avoid any unwanted surprises.
And the question is; should i use same style factory pistons? I would like to keep costs down on bottom end and keep the clearence between piston and valve. But if there is something similar or better moneywise then why not. It would be nice to use floating pin setup so i dont need to pay extra for machine shop. I really didnt thought about crankshaft and rods because i didnt wanted to get involved in total rebuild, well now i have the engine in the back of ford explorer!
Yeah, this stuff snowballs quickly. You may want to think about a cast stroker assembly kit. It'll come with everything you need to screw the bottom together sans machine work. Add up all the costs of reconditioning the crank/rods/new pistons, etc and weigh it against the cost of a kit.
Stroker motors are absolute animals that have extremely good street manors. Think about it.
Duke5A's advice is pretty sound in this respect.
Most of the time by the time you add up all those individual pieces together you end up paying more. Meanwhile, buying a kit at least removes the possibility of "oops, these two things no longer match/can't be made to work together".
Regarding the cylinder bore wear. Are you talking about the top ridge, which usually results over many many miles as the cylinder combustion pressure pushes against the piston and the rings themselves push against the bore, thus wearing it down. Or are you noticing overall wear throughout the whole cylinder bore?
You can cut the ridge out, or at the very least make sure this simply isn't the build-up of the deposits and is a real metal wear.
If the wear is not too bad you could hone your cylinders at home, well, sort of...with a manual honing ball, but for the most part that's just to remove the cylinder bore glaze and give the new rings a good surface to seal up against. You wouldn't do this instead of a cylinder hone job at a machine shop.
Man get a chain on that short block…
I have one but dont have the intake plate yet
The wear is noticeable up to piston ring top stroke point. 90% of cylinder walls are smooth without honing structures.
I was thinking about stroker but it costs about 2600$ without machine job wich is above my budget for this moment.
Boring 8 cylinders along with other machine jobs would cost me somwhere around 1200$ wich makes it more acceptable around this part of the word.
