318 Aspen with magnum heads.
This is and old thread, I didn't even take into account that you're in Poland. Yeah, importing parts would be expensive. Clean the crank up, recondition the rods with new bolts (ARP if you can), zero deck the block and run a piston with a quench pad. Shoot for 9.5:1 to 9:1 compression. Should make for a good rotating assembly that is budget minded.
You don’t need a lifting plate to use a chain, just a couple of bolt holes and bolts. What you are doing there is down right dangerous…
