Got burned by ‘it ran when pulled’! I’ve had cylinders sleeved due to rust, but never one that’s been windowed. This is a 71 340 block. Has anyone here successfully sleeved and raced a cylinder that looked like this?
Yeah it’s scary looking to me. The 340 motor in and of itself has some nostalgia to it. The last time I had a sleeve done it was like $80 IIRC. I have some 318s, 340s and 360s but I’d hate to toss a 340 as junk if it wasn’t.Yikes. Any particular reason to run a 340? Class racing? Going to be a lot cheaper to grab a 360 LA or Magnum that doesn't have a hole in the bore vs fixing that 340. Should be able to get a block for $200.
Even with the crack that goes from the hole to the bottom of the cylinder? Do you think that would need more work than just the sleeve?sleeve it and run it.
if your worried about the crack, get it welded then sleeve it.Even with the crack that goes from the hole to the bottom of the cylinder? Do you think that would need more work than just the sleeve?
Im tempted to try to weld the cracks and then have it sleeved. I’m gonna take it to the machine shop and see what they say. Will report backI see three cracks running to the bottom of the cylinder, looks risky to me, if you sleeve it I would expect problems with water in oil. I see a junk block.
Thanks! Yep trying to decide if it’s worth it. We have a good machine shop in town but I haven’t been able to get off work to go yet. The rod was ‘only’ bent but the piston was in pieces.I've sleeved a lot of engines. Just know that it has gone up. It's going to be expensive and there is a lot of machining involved. The block you have had better be worth it. They used to be cheap to sleeve, and by cheap I mean like $100 a cylinder PLUS the machine work. Not now. Sleeving was a way to save a block that was not replaceable. That was when machine shops were still abundant and they were not a fortune. They are a lot more now and you had better really trust the kids in the shop.
That block may have cracks or shifting. Tank it and have it checked really well. Most of my picture windows are down in the side of the block above the pan rail (near the crank) or between the frost plug holes. I usually get them where the rod breaks and tries to force it's way out down low, beneath the cylinder before it can even come back up. That indicates something else. A rod didn't break, or not likely. I would like to know what was going on in those cylinders.
I’m hoping I can. I had planned to have it at the machine shop already but some other obligations have gotten in the way. I should know soon tho.I have sleeved blocks similar to yours with
no adverse effects.
Yeah it’s a pretty gnarly hole but I’ll see what can be done with it. There’s a fair bit of nostalgia in the 340 engine even tho newer motors make more power. Thanks!My Gremlin has 3 sleeves in it. 401 blocks are hard to come by. Sleeving and machine shops in general is getting a lot more expensive. If you have to save it, you definitely can. If you decide not to, keep it stored properly and keep it well oiled so the cylinders don't rust up. There could come a day when that block is worth a lot more or you change your mind and you decide to sleeve it.
