87 m body lean burn remove
mopops
wappingers ny
87 5th ave, i know the info is here but cant find it. i know the parts i need , i need the wire diagram for a color blind guy tks gjg
Mr C
Colour blind...that is tough when you talk wiring since it's all coloured.
Here's the best pic I could find with added text:
mopops
wappingers ny
tks I can use ohm meter to find wires this is a great help. I am getting a kit from ehrenberg , can i use my coil or does it need to be changed? tks for the help g j glover
Your existing coil will be fine. Regular electronic ignition and Lean Burn/Electronic Spark Control use the same coil. Doesn't apply but, a points system uses a different coil than electronic.
mopops
wappingers ny
good news thank you, that saves a few bucks g j glover
Remow2112
There are a couple of options if you want to get rid of the resistor and put a better coil on too.
