Accelerator cable for super six in a 1980 Volare
shadango
Pittsburgh, PA
For our super six conversion, I know we need a new (shorter) accelerator cable for our 1980 Volare....as well as a new kickdown setup (I think I have resigned to going with the pricey Bouchillon setup for ease of install and use) and a new accelerator cable bracket /return spring bracket at the carb.
Accelerator cable:
Problem is , on Rock Auto, they ONLY list a few part numbers and all are for 1bbl and/or standard trans.....and all about the same length (25-30 inches). Anyone know what length the super six/2bbl cable should be and wear to find it?
Cable bracket and return spring bracket:
had almost forgot about these --- I found a carb but it doesnt have the brackets I need I dont think. Ideas?
The super 6 carburetor is mounted a different direction than 1-bbl carburetors are.
A /6 2-bbl throttle cable, from Chrysler, is part # 4095320
It is 30.25” long (the /6 1-bbl is 25.75” long).
Pioneer makes part # CA8415 that will fit (available at O’riellys and maybe other locations). There maybe other cable manufactures, as well.
If anyone is getting a super 6 changeover, be sure to get the throttle cable, kickdown linkage, fuel line and air cleaner, while there.
shadango
Pittsburgh, PA
shadango
Pittsburgh, PA
I was under the impression that the supersix cable is actually shorter than the 1 bbl?
Some say the v8 cable is the bone robust which is shorter yet at 19 inches....
Now I am confused.
