Best quality carpet
I forgot about the seat bolts also, you should put them in so you can find the holes .
Opticon77
SE PA
I seem to remember the option get the 60s style nylon loop carpet in the Volare shapes not that long ago. Did ACC and Stock Interiors do away with that or am I just looking at the wrong carpet manufacturers?
Late answer to one question from a couple days ago. Yes, the carpet comes with the jute backing attached, just like the original.
It does appear it's only available in cut pile, not the loop style.
near Allentown, PA
Aspen 500 is right - at least as far as what Stock Interiors offers. The jute backing is already attached, but there are no holes in the carpet for seat belts, shifters, dimmer switches, etc. The carpet does come with a new repro dimmer switch grommet to use however. For the F bodies, only the cut pile is available. But, it is quite nice and thick.
I had one of those measure 5 times, and then measure again, and then once more just to be sure, before cutting for the console brackets. You can always cut more, but you can't put it back:D
