Determine Which Model of 4 speed OD Automatic Transmission I Have?
Fresh Air Inspector
Yarmouth, NS, Canada
Hello All,
I've been going around in circles trying to figure out which version of Dodge automatic I have.
The know it came from a 1995 Dodge Dakota pick-up with the 318 V8. The number on the side of the rail for the ATF pan is;
PK5211832421083192.
Depending on which website I go to it is either an A500, A518, 42RH, 44RH or 46RH which is a royal PITA. Makes sourcing any parts difficult. :-)
The transmission is currently at my brother's place about 2,000 km (1,200 mi), away so I can't physically check anything. I do have a number of pictures if that helps the detectives out there.
Looking forward to the feedback.
Hello Both,
Thanks for the quick reply. I know it is an RH version as it only has two electrical connectors; a 3 pin (12V, OD, TCC), and 2 pin (neutral / park). As for the pan, below is a picture - hope that helps.
That's a 518/46RH. The 46RH designation was just a name change for the transmission. It's based on the 727.
Hello Duke5A,
You're the man!!! Brilliant, I was hoping it was a A518 / 46RH. You have no idea how many hours I spent trying to determine what version I have.
Thank you!
