Difference in X and J heads?
79aspenrt
New Member
I bought a 340 yesterday and guy said it came with a set of J heads and when I got it home and cleaned up I noticed it had one X and one J head. I know there is a difference in valve size and springs. but do they have the same size chambers inside? Because im going the have the valves and springs replaced anyways I was wondering if I had the valves upsized to 202 160 like the X would they be the same or would I need to find another X
79aspenrt
New Member
Ok that was what I was thinking just wanted to get a second opinion. I appreciate the reply.
Greg55_99
Do J heads require a larger seat to fit the 2.02 valves?
Greg
Greg55_99
Ah... So the answer is to mill out the existing seat of the J head and drop in 2.02 valves. I did now know that.
Greg
GTX JOHN
Early J Heads have 202 valve just like X. On our stock eliminator
stuff no flow difference between intake valves size(202 to 188) assuming stock ports.
The X heads average about 7 - 8 CFM more flow @ 400 lift than the J heads .
Also combustion chamber centering to block is much better on X heads.
I would prefer to have the same casting # head on my engine rather than different
ones for performance.
