I should be ok. New Springs are 6 leaf and a slight taller shackle. I'm really curious what all the combo lengths are.Doesn't the 8 1/4" need a shorter shaft than a 7 1/4"? One quick and dirty way to see if the shaft is too long, with the car supported on the suspension, unhook the shaft and push it all the way into the trans. See how much space there is between the u-joint and yoke. If you've got at least 1/2" or so, should be fine. Main thing is the front yoke never bottoms in the trans when the suspension travels.
thanksAn 8¼” driveshaft is 1.6” shorter than a 7¼” driveshaft is.
Enough difference to cause troubles.
I will try to find out the correct lengths, tomorrow.
thanks brother.View attachment 20715
From my '77 Parts Manual.
H, N is Aspen Volare and F, G Lebaron Diplomat
(R,W,X,S is B-body so pay no attention to last two lines)
The only thing it doesn't mention is differential type - but a huge majority were 7¼” – so shouldn’t be too hard to figure out.
The differences are:
2 vs. 4-door (apx. 4” difference)
7¼” vs. 8¼” (apx. 1.6” difference)
727 vs. everything else (apx. 4.1-4.2” difference).
All FMJ’s came with the small U-joints from factory (315G or 245/246).
I see six different propeller shaft lengths:
44.74” - obviously is 2-door, 727 and 8¼”
48.60”
48.89”
50.45”
52.70”
54.45” – obviously is 4-door, 904 and 7¼”.
Same here.I've always had very good luck with the local shop building or shortening driveshafts.
