Electronic Fuel Control System Delete
ScubaSteve
Hey y'all
Got a 1986 Plymouth Caravelle with a 318 5.2 V8, Its the longer cousin to the Diplomat. I want to delete this stupid "Electronic Fuel Control System" and switch to good old fashioned analog. Now I did try to delete it way back when and I found that I could get damn near but my distributor had to be plugged into the system or else it wouldn't fire so I had to keep it.... for now.
What exactly would I need to scrap all the junk and go to a beautiful clean carb with a beautiful clean fresh air intake. I do know I would need a new distributor but is that really it?
Step by step instructions would be appreciated and the name of the part and where to get it.
You need a new carb, vacuum distributor, ecu and wiring. This change is already well documented online, there should be step by step posts about it in the forum here also.
You can get all the parts from rock auto. Dealers used to have the wiring under mopar performance, don't know if they do anymore. Some places like summit racing also sell a kit that has everything but the carb. Look for small block electronic ignition conversion.
Basically what Mike said. Is it all still functioning? And are you doing this as a stepping stone to further upgrades?
Hey y'all
The following document might be useful in doing the conversion the Chrysler electronic ignition:
Note that I wrote this from memory, some notes, and some manual checks 30 years after I did my last conversion. It is also generalized and covers the multiple versions of the systems used 1976 - 1989. If you use the procedure document and find some details that need to be adjusted or added, particularly with the 1980s Electronic Fuel Control System, let me know and I'll update it.
Later Mopar Performance Books covering ignition systems, such as the P5249010 Engines Manual, also have conversion instructions.
The "Electronic Fuel Control System" computer does three main functions:
Ignition,
Computer controlled carburetor, and
Emission controls.
There is little interaction between the three functions.
Also, there is no way to ask that computer for trouble codes nor to look at any values.
On my '86 Fifth Ave, I replaced the Holley 2-bbl (computer controlled) with a Chinese made '77 Carter BBD (non-computer controlled). The computer is trying to control the fuel system - but carburetor is ignoring it. Been that way for years without any issues.
The computer is still running the ignition system and not giving me any issues there, either.
Where applicable, most people who get rid of the computer, will do so with an Electronic Ignition System changeover and a replacement carburetor. They also do an "emission system delete" (again, where applicable), which is disabling the AIR pump and EGR systems.
Note: I DO NOT LIKE HOLLEYs, so I got a Carter BBD (or Chinese knockoff). To do that, get one before Lean Burn, so '77 or older. You will also need to replace the choke thermostat, for one is about 1/4 inch longer than the other (Carter vs Holley).
I would rather have an expensive bonfire (ie: burn the car) than drive one with a Holley on it. Wait, that might not be enough.
Mr Vaanth is awesome tech support
I don't find replacing the carb in the instructions
Thanks!
Carburetor replacement, or retaining with modification, is covered under Carburetor Considerations in the document. 1981 and later feedback carburetors should be replaced as noted. Earlier carburetors are recommended to replace, but can be used, some with modification. Adding a vacuum advance port is mentioned, and a procedure for the Thermo-Quad is detailed.
