WANTED Female seat belt buckle and 4bbl kickdown linkage set up
Mopar&vettedude
Tonwanda, ny
As the title States I am looking for the belt buckle female end for my cordoba. The driver is starting to crack and fall apart, also I am looking for the full kickdown linkage set up for a 4bbl. Let me know. Thanks CW.
I don’t have either (for sale), but I thought you might clarify your request.
4 bbl for 318/360, for /6 or big block?
904/998/999 or 727 (they are slightly different).
Note: a lot of people are selling small block setups that is not the correct parts for a 4-bbl – so if in doubt, post pictures.
If not able to find a 4-bbl setup, Lokar makes a great cable setup and is worth considering.
Will a seatbelt for an Imperial work?
I know it is neither blue or black? I can grab it on Presidents day.
Or will this work with the dark blue interior? I think it is the 60/40 plush seat. Are the belts different?
She is in the same yard. Can't remember, but I think they are all 2 BBL. Again, Gator and I will be trudging the junkyard on the 20th. Is it a hex or torx bolt? Either way- I'll have them both, but I'll pre-load the electric impact gun in "ready mode". I have to stop bringing 180 pounds of tools into the yard, so I go with exactly what I need to pull with.
I would think Cordoba, Mirada and Imperial would be the same. Might be the same as any FMJ 2 door . . . maybe.
Will take a 13/16” socket (same size as spark plug) at 2 or 3 locations. Flat screwdriver for top cover and maybe a Phillips for seat attachment (which if seat attachments are good, grab).
4-door front outer belt will be different. Inner's might be the same.
thanks Bud
I'm set for junkn
Sorry about posting late, but yes the seat belts out of the imp work as well.
headed there next Monday. Private message me your phone/ text number and I'll text you a price before I pullit. If you dig the price I grab it and we can go from there. Should be really cheap.
The socket size is 13/16” (again), but the first few turns are rather tight (Loctite?).
I’d recommend taking a long ½” drive socket wrench and maybe a 3/8” socket wrench and adaptor to finish ‘em off.
thanks man. Yeah, I'm still not 100% up on strength, so just taking tools (the exact tools) I need and not the whole bag.
And just found that both cars have the dreaded broken sleeve (the twisted plastic tunnel the belt is inside of) Where does the electric connector unplug from? under the seat?
1983 J Body
1 BELT, Front Seat Lap Buckle Inner Label No. 4054666 N N N N0
F758 AA3 1 Silver N N N YF758AA3
F758 SC7 1 Blue, Dark N N N YF758SC7
F758 TM6 1 Red N N N YF758TM6
F758 BL3 1 Tan N N N YF758BL3
Label No. 4316753, Left N N N N0
F709 BA3 1 Silver N N N YF709BA3
F709 BC7 1 Blue, Dark N N N YF709BC7
F709 BM6 1 Red N N N YF709BM6
F709 BL3 1 Tan N N N YF709BL3
2 BELT, Front Seat Center N N N N0
Buckle Half, Label No. 4250464 N N N N0
F658 BA3 1 Silver N N N YF658BA3
F658 BC7 1 Blue, Dark N N N YF658BC7
F658 BM6 1 Red N N N YF658BM6
F658 BL3 1 Tan N N N YF658BL3
Tip Half, Label No. 4290459 N N N N0
F653 BA3 1 Silver N N N YF653BA3
F653 BC7 1 Blue, Dark N N N YF653BC7
F653 BM6 1 Red N N N YF653BM6
F653 BL3 1 Tan N N N YF653BL3
3 F814 JX9 2 COVER, Front Seat Lap Belt Tunnel Anchor Bolt, Black N N N
YF814JX9
4 6030 458 AR BOLT N N N Y6030458
5 AR SPACER (not serviced) N N N N0
6 4172 807 1 BRACKET, Unibelt Solenoid Mounting N NY N Y4172807
7 4172 808 1 SOLENOID, Unibelt N NY N Y4172808
I have this one NOS:
F709BL3 LF inboard tan or cashmere it has Label No. 4316753 on it
1983 J Body
YF814JX9
Are any tan covers available for a 1980 Chrysler Cordoba? My driver's side female seat belt cover is disintegrating, probably due to UV.
slant6billy, that would be great, but the Imp's cover may have the same issue. The one in my Cordoba is dried out and stiff, so if you put just a slight pressure on it, it crumbles. It is so stiff that it has worn a hole on the driver's seat bolster, towards the middle of the car. Strangely enough, no issue on the passenger side. Seat is a 60/40 split bench (power, if it makes a difference). If I can't get a reasonably priced replacement, I may just have to remove the plastic cover, and leave the seatbelt without a cover, just to avoid any more seat bolster damage.
