Fuel Line
tube is tube. aluminum doesn't bend very nicely. tends to crack when it has had enough movement. use some copper/steel line instead
Depends on what line. Use the new easy to bend stuff.
You get what you pay for, the cheap stuff can start rusting pretty quickly.
I wanna change the line from the fuel filter to carb I have a metal line now but they guy cut it shorter so that would be 3/8" ? where dod get the good stuff not looking to buy cheap
I'm thinking factory was all 5/16"...no?
Anyways, if you go bigger that's no problem (nor value add) providing that you match up correctly at both ends, meaning: good hose clamp and carb fitting match.
But to avoid all that trouble I'd rather run with a factory size.
Yeah I'd stick with 5/16" steel line for that application, you can get good pre-bent stuff from Classic Industries or just get straight sections from NAPA and bend it yourself.
can anyone post a picture of the heater control vale installed on there car (318 engine) mine has a bracket connected to the top that holds the radiator hose all the ones I see dont have that.
