Removing rust has never been easier!
www.evporust.com
Evapo-rust rust remover
[SIZE=-1]EVAPO-RUST is an amazing award winning rust REMOVER which is utilized by the U.S. Army, U.S. Navy, U.S. Air Force, FBI, NATO, Government Contractors, Engine Builders, Auto Enthusiasts, Gunsmiths, Forensic Labs, OEM’s, Farmers, Antique Restorers and more. [/SIZE]
[SIZE=-1]EVAPO-RUST is non-corrosive to steel and does not harm brass, copper, aluminum, gold, lead, titanium, steel, cast iron, chrome, solder points, vinyl, plastic, rubber, silicone, glass, cork, or wood. EVAPO-RUST has an indefinite shelf life* and can be used over and over until it absolutely stops working. On average, one gallon de-rusts up to 300 pounds of light to moderately rusted steel.[/SIZE]
Evapo-rust is easy to use
[SIZE=-1]EVAPO-RUST is easy to use. Fully immerse the rusted item in EVAPO-RUST and check progress in about 30 minutes; no scrubbing necessary. Soak times will vary from 30 minutes to 24 hours depending on severity of rust, type of steel, and temperature. EVAPO-RUST is water based, therefore the active molecules will slow down as temperature decreases and increase as temperature increases. We recommend utilizing EVAPO-RUST at a bath temperature above 60° F.[/SIZE]
[SIZE=-1]EVAPO-RUST has a surfactant to aid in penetrating oils and dirt. However, surface contaminants do slow the process and can shorten the life of EVAPO-RUST . Oils, greases and cosmoline should be removed prior to de-rusting. Cleaning the part prior to soaking in EVAPO-RUST will also help in the disposal of the spent product.[/SIZE]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]
YES, EVEN MOTORCYCLE GAS TANKS[/FONT]
[SIZE=-1]You can use Evapo-Rust to remove the rust from a gas tank in one of two ways described below, depending on if your tank is still attached or has been removed:[/SIZE]
[SIZE=-1]1) Completely fill the tank with Evapo-Rust and allow to sit for 2 – 4 hours. Drain completely and rinse well with water. Air dry and fill with gasoline immediately to eliminate flash rust.[/SIZE]
[SIZE=-1]2) Pour in 1 gallon of Evapo-Rust and rotate gas tank every hour until the rust has been removed. Drain completely and rinse well with water. Air dry and fill with gasoline immediately to eliminate flash rust.[/SIZE]
NOTE:[SIZE=-1] Althought Evapo-rust rust remover is designed to be a soak, it can be utilized in certain situations as a spray.
Click here to view how a chassis was de-rusted using Evapo-Rust as a spray to de-rust a chassis.[/SIZE]
