M bodys etc are so hard to change oil filter
Really? It's right there easy to get to. Some cars you can hardly get your hand up to where they are and you need to turn them on all sorts of different angles to get them out dumping dirty oil down your arm and all over the place in the process. These ones are a piece of cake.
I use K&N gold filters. They have a stamped nut that’s spot welded onto the bottom of the can, so you can get them on and off real easy with a ratchet, extension and socket. I switched to them after I installed headers on the car. Can’t really get a filter wrench up there anymore and if I do, don’t have much room to turn it.
Change the filter on the current RAM 2500/3500 trucks with the Cummins diesel and you will think your M-body is just fine, if you don't go insane changing the Cummins one firsto_O
Sub03
Norway
Don't get me started on VW/Audi. Everything i try to do on them make my arms look like i've been in a catfight. Seems like they build the car arond the engine, and at the end of the day you are stuck because you need to buy some special tool to finish the job.
Our cars is a joy to wrench on with longitudinal engine/trans with lots of space around.
I worked at an Audi dealer for 6 years and know your pain well. Best thing I've ever done was to GTFO of there!
69-
Germany
Hey, thats a great engine, had an A6 V8 (with the extended hood) years ago. Engine never let me down and all was cool for normal tune ups. Unless you would have the RS6 V8- twin turbo. Service Manual for plug change: 1. Remove the engine
:D
M-bodies are a walk in the park...
MoparDan
Daytona Beach, FL
Try changing the oil filter on a wrong wheel drive '88 Olds Touring Sedan...it's like GM designed it so you couldn't reach the filter!
ZieglerSpeed
De Graff, Minnesota
I wouldn't waste my time on a GM. Try changingg the hi beam indicater bulb on an 83 Olds 88. The dash will be on the seat, it'll need a new circuit board, 400 dollars if you hire the job out
:D
2004 VW Passat W8 starter replacement. Step one: Lower powertrain assembly from vehicle. Sigh...............................................Headlamp bulb replacement on many different vehicles, step one: Remove front bumper cover. Change battery in some Chrysler and Dodge vehicles step one: Remove right front tire, remove forward portion of inner fender liner..................Sometimes you'd like to have 5 minutes in a room alone with automotive engineers:mad: Seriously. In the end though, all you can do is take a deep breath, dive in and have at it, 5 days a week, 8 1/2 hours a day for 45 years or so and then, retire.:cool:
Come on now, some of those dodge/Chrysler vehicles, you trade off the shitty battery placement for having the oil filter right on top of the engine. Loved doing the oil changes on the Chrysler 200 I had. That 3.6 Pentastar isn’t a terrible little engine.
Ever tried to change the exhaust manifold on a 3.6L?
The oil changes might be easy - but the exhaust manifold is a completly different topic. It is almost as if it wasn't even there.
No, but, I did replace the intake manifold and plastic thermostat housing when it was -20 outside, lol. Those were both easy as, pie. Isn’t the exhaust basically cast off the head?
SlantSixSullivan
East Liverpool, OH
The filter on the 05 Touareg 4.2 isn't bad, but it has an upper and lower drain plug (two piece pan I think?). And of course, the lower one is the one seized in there, so I can't do a complete oil change.
MoparDan
Daytona Beach, FL
Upper and lower drain plugs? Man, for some reason this brought back memories of this one time I changed the oil on my friend's son's Fox body 5.0 Mustang (89 I think) that thing had two drain plugs one towards the front of the oil pan and towards the back of it I'd never seen anything like that before!
SlantSixSullivan
East Liverpool, OH
Well, three drain plugs actually. The filter housing has one too. The pan was aluminum, with what appeared to be stainless (but may not have been) female torx plugs.
