ZieglerSpeed
I HATE these cars. I'm gonna fix it with a stick a dynamite
Change the filter on the current RAM 2500/3500 trucks with the Cummins diesel and you will think your M-body is just fine, if you don't go insane changing the Cummins one first
2004 VW Passat W8 starter replacement. Step one: Lower powertrain assembly from vehicle. Sigh...............................................Headlamp bulb replacement on many different vehicles, step one: Remove front bumper cover. Change battery in some Chrysler and Dodge vehicles step one: Remove right front tire, remove forward portion of inner fender liner..................Sometimes you'd like to have 5 minutes in a room alone with automotive engineersHey, thats a great engine, had an A6 V8 (with the extended hood) years ago. Engine never let me down and all was cool for normal tune ups. Unless you would have the RS6 V8- twin turbo. Service Manual for plug change: 1. Remove the engine
M-bodies are a walk in the park...
 Seriously. In the end though, all you can do is take a deep breath, dive in and have at it, 5 days a week, 8 1/2 hours a day for 45 years or so and then, retire.
No, but, I did replace the intake manifold and plastic thermostat housing when it was -20 outside, lol. Those were both easy as, pie. Isn’t the exhaust basically cast off the head?The oil changes might be easy - but the exhaust manifold is a completly different topic. It is almost as if it wasn't even there.
Don't get me started on VW/Audi. Everything i try to do on them make my arms look like i've been in a catfight. Seems like they build the car arond the engine, and at the end of the day you are stuck because you need to buy some special tool to finish the job.
Our cars is a joy to wrench on with longitudinal engine/trans with lots of space around.
Upper and lower drain plugs? Man, for some reason this brought back memories of this one time I changed the oil on my friend's son's Fox body 5.0 Mustang (89 I think) that thing had two drain plugs one towards the front of the oil pan and towards the back of it I'd never seen anything like that before!The filter on the 05 Touareg 4.2 isn't bad, but it has an upper and lower drain plug (two piece pan I think?). And of course, the lower one is the one seized in there, so I can't do a complete oil change.
Well, three drain plugs actually. The filter housing has one too. The pan was aluminum, with what appeared to be stainless (but may not have been) female torx plugs.Upper and lower drain plugs? Man, for some reason this brought back memories of this one time I changed the oil on my friend's son's Fox body 5.0 Mustang (89 I think) that thing had two drain plugs one towards the front of the oil pan and towards the back of it I'd never seen anything like that before!
