Mr.Lopar
post the pics
thanks ramenth:wave:spike! Welcome aboard!
They aren't posting quality, will make better ones later....post the pics![]()
trying again, looks like the daktoa has more front frame than the FMJ, would have to be trimmed....I copied from service manuals the needed pics, had to resize them to make all have the same wheelbase on paper. They didn't use the same scale on the Dak drawings as the FMJ drawings.
The Dak frame is a bit short ahead of the front tires, a good thing if you are dropping an FMJ on a Dak frame. The Dak frame has a different rise where the rear seats would be, means not having a thick cushioned comfy rear seat bottom. And of course the trunk area would have to be cut out and made to fit the rear of the Dak frame. It would probablly be easier to keep the rear frame of the FMJ and splice it to the Dak frame.
I think the biggest issue is the height of the engine as it sits on the frame. Looks like the Dak engine sits quite a bit higher....certainly the tranny hump does....I suspect a dakota hump would have to be put into the FMJ but then the drive shaft will be at a steeper angle.
so am I.....I think what REALLY appeals to me about this is, it solves a couple of issues I have. Big block in an F-body is no big deal, but the Dakota frame strengthens the structure, gives POWER rack and pinion and eliminates the transverse torsion bars. None of these items are real problems, but, I like there are quite a few suspension upgrades available for the Dak front end. Tubular A-arms, big brakes and a kit to lower the front end. Also, compared to the Alterkation front end.... it's really inexpensive. Just takes a LOT of work to get it in......
I'm tempted....
Greg
There are two Mopar dirt racers that are facing a rulebook change that will effectively outlaw the torsion bar front end. A track surface changes, put two turns on the right front bar and, BINGO! instant complaining of an unfair advantage.
I for one would want the 9.25 axle....
