Part name, headlight alignment clip
MoparDan
Daytona Beach, FL
It's the clip that holds the top of the headlight up, what's the name of it and how hard is it to find? Screenshot_20251015-161925~2.png
It's the clip that holds the top of the headlight up, what's the name of it and how hard is it to find?View attachment 57001
Chrysler calls the part pictured "SCREW, Nut, Sealed Beam Unit". The original part number for a 1985 Gran Fury is 3868985 (superseded by 5201359). The aftermarket calls them "headlight adjustment screw", "headlight adjuster", "headlamp adjuster", or similar.
According to Dorman, their number 42188 or 700010 is a replacement, plus 42187 is also a replacement, but it's a multi-fit kit with two styles. Some restoration places carry a few, mostly for earlier cars.
Dorman's older stuff, including the "Help!" line prior to them acquiring it, is better than the newer products. The current parts seem to have a lot of negative reviews about breakage.
Auveco 3009R is a replacement for 3868985. These are better quality than Dorman. 11848 is an old Auveco number that is apparently discontinued, but might be found.
I've had mixed success using some aftermarket adjusters. Some are too small, or don't otherwise fit right. I've pulled many original pieces over the years and saved them if good, so I usually use those.
The aftermarket ones at Autozone and the like are terrible.
you can get em at any auto parts store but in my experience they love to break when you push them into their correct place (the tabs will fly off if you push too hard) so i just stuck the plastic bit behind where it's supposed to go. it's also useful to save the original screw as the one that comes with the replacement won't fit the stock headlight bucket. they also sell generic ones that in my experience don't work
There's cracks in the fiberglass around where the clip would go, so it wouldn't hold anyway, I did use the original screw.
