Radiator question
mpdave391
Anyone running after market radiators
If so what brand. Did you end up going with I’m. Looking at going with a new rad for my 79 volare but having a hard time finding something that might work I found a cold case one 26in for a Plymouth roadrunner But I’m not sure
Champion CC374. You need to make a plate for the driver's side to mount it, but it's pretty easy. I've had this radiator in the car for 12 years now.
I used a chinesium aluminum radiator for a 1964-66 mustang for my slant 6 since the hose locations lined up pretty well and they are still surprisingly under $100. You just need to make mounting plates to attach it to the radiator support, it has been working for 3 years now. That probably won't work for a V8 though
I used a CC 374B Champion in my Aspen wagon. I don't recall the original application, but I do remember researching measurements from different applications and used the one that provided the most clearance between the K-frame & lower radiator hose. I may have drilled or adjusted some holes in the flanges to adjust the fit but I'm pretty sure I didn't add any brackets.
If you can blow up the pic, you'll see the part number on the radiator where the shroud mounts in the last photo.
I did have to make some minor adjustments to the radiator in a couple of spots.
First pics are what came out and what went in.
