WANTED Small parts wanted
Kramer79
Connecticut
Hello,
Looking for a few small parts for 81 diplomat wagon:
- Window crank round black knob
- Metal interior back door release handle (drivers side rear if that matters)
- Emergency brake rubber cover
Any slant six performance items- just in case I had to ask…
Thanks!!!
The window crank knob is part of the window handle. The window crank p/n is 3882764. A lot of new ones on eBay - but many are re-pops.
The inside door handle is the same for front and rear doors - but different between Right and Left doors. I think any M-body will work. The Right side p/n is 4184140. I found a couple on eBay.
The park brake rubber pad p/n is 2467513. The same part used sense the '60's.
Here is a decent priced used one: MOPAR some 60s 70s EMERGENCY BRAKE PEDAL PAD DODGE PLYMOUTH CHRYSLER | eBay
Kramer79
Connecticut
Thanks so much!!! Crank and pad ordered up! I think I need left side handle if it is drivers side? Thanks again
The front and rear inside door handles are slightly different but are interchangeable. I don't know why they list as single number in parts books.
The Left side inner door handle p/n is 4184141.
I've not done a side by side compairison of the front and rear handles - so you might be right. I've only looked at the p/n's
I only know they're different because years ago the drivers one snapped off on mine and I swapped it with the rear. They fit but the square handle part is a bit higher or lower.
I checked the part numbers in the 84 book and like you said they both list the same #.
Kramer79
Connecticut
Thanks- driver side must be more common to break off… 50/60$ on eBay! Passenger had one for 7…. I’ll ask some of the parts cars on here as they come up
near Allentown, PA
50/60$ on eBay!
That's just nuts. Your best bet might be the parts vender area of a car show like Chryslers @ Carlisle.
MoparDan
Daytona Beach, FL
$50.!? That's insane, $15. the most I remember ever paying for one. I have no idea what they want for them but the '87 Fifth Avenue from Moye's has all 4 interior door handles
