84Furyus
Note: If you are actually serious about a turbo you are going to want to think about how you intend to fuel it now. AND the pistons you're sticking in it.
Scenario 1: MPFI with forged pistons and ethanol blends? You'll have enough accuracy and resistance to preignition for decent boost levels near 10:1 base compression. Expensive.
Scenario 2: A sloppy blow thru carb and stockish hypereutectic pistons on clear gasoline? Better just throw on some 360 heads, tank your base compression, run it rich, and use a good intercooler for insurance. Cheap... at least until you melt the pistons a few times.
If I do turbo it later on it would most likely be draw through carb setup and only like 5psi. Running a little rich and setting up a timing controller on pump 91 gas. I know there's some guys running 10 psi on the stock bottom end 318s on some of the turbo forums with good luck and they are doing it with a carb and locked dizzy.
It's a thought not something that's 100% going to happen. For the time being just wanting to get close to 300 hp out of the mostly stock 318.
