Has anyone installed a non-Chrysler sway bar (either front or rear) on their F, M or J body?
If so, I want to know who you used and how did it go?
Any comments about the install?
I have two cars to install sway bars on. Also, I have one pair of complete police bars.
My plan was to install the police bars on my ’77 wagon (replace the front and add to the rear) and then purchase a pair of bigger bars for my ’86 5th Ave, sense it is a heaver car.
I’m not seeing a lot of options out there for these cars.
So far the ones I have found are:
Front:
Stock FMJ (non-police) 1"
Police FM 1-1/4"
Mopar Performance P4286722 1" (no longer available)
ADDCO 893 1-1/8” (need to reuse hardware) (apx $230)
Firm Feel SBFFMJ81 1-1/8” ($335 + H/D brackets are $60 extra)
Rear:
Stock FMJ (do not come with or N/A)
Police FM ¾”
Mopar Performance P4286708 ¾” (no longer available)
ADDCO 270 ¾” Differential mounted bar. Comes with hardware. (apx $220)
ADDCO 437 1” (need to reuse hardware) – and I don’t have any! (apx $260)
Firm Feel SBRFMJ1 ¾” Frame mounted bar ($395)
Firm Feel SBRFMJ2 7/8” Frame mounted bar ($395)
I would like to get this done without forking over $800 (US), if I can avoid it.
Does anyone know of other sway bars that will fit?
In addition to the above, I have a rear sway bar I bought from Mopar Performance 30 years ago, for my ’68 Charger (vehicle went up in smoke before installation). I think this bar might fit – but not entirely sure.
The police bar is a frame mounted bar (ends at the leaf spring/differential plates), whereas the MP bar is a differential mounted bar (ends at the frame rail) – so frame rail distance is the determining factor.
This bar MP part # is P4286723 and I “think: was made by ADDCO (#919 ¾”), but not sure.
Oddly, the FMJ police bar will work in the ’68 B-body sense it is not dependent on frame rail distance (like the MP one is) and the differential perch distance is the same. I'm not sure the other way around.
Front:
Police FM 1-1/4"
Rear:
Police FM ¾”
