I've got this same problem. It started out by a delay then banging hard into reverse. Then it got worse. If you touched the gas at all in reverse or have to back up a slight hill, it will kick in and out and grind like hell. Sometimes no reverse at all! All three forward gears work nice an crisp as they should. Fluid is red and full, hence I didn't change it yet. I think I will try a fluid/filter change and switch to ATF-4 as everyone is recommending now. I'd like to adjust the bands. How do you do that?
Let me do some digging when I get home.
It's in one of my books....unless someone chimes in first.
