1977 gas tank swap
Ed Dorey
Kearney, mo
I'm curious if I can swap a 78 gas tank into the 77 if I have the fuel sending unit and filler neck from the 78. I know they're different but wanting to come up with something that works
volare 1977
strap locations are different etc, just won`t work, you can change trunk floor pans if handy with welder, lots of work
Can I bolt up an 88 5th Ave fuel tank into a 79 LeBaron coupe?
Rock auto shows a split in 79 with the newer tank being the sane up to 89. It looks like the tanks are the same except for the added hole so it should fit
That is the only difference. "Up to" has a vent hose nipple (rollover valve is behind the rocker in the cowl area), "after" takes a grommet and valve. Direct bolt in for your 5th Ave.
Don't forget a new filler tube grommet :) If possible, get one from the dealer. Some of the aftermarket ones are cheaper but quality and fit can be hit or leak, I mean miss, lol.
volare 1977
4002010 is thefiller neck grommet part number. I may have a extra around here if you need one.
