I already have the 833od trans for my f body . . . and the 318 is . . . dirt cheap.
This is the “missing” fact that allowed us to get a bit sidetracked (somewhat).
I’m not picking on you – for I have asked questions without presenting all of the facts, myself.
For a stock 318 or 360 or even a mildly built 318 – the 7¼” will work . . . for a while – as long as you don’t let your clutch foot slip off of the clutch petal at a high RPM, too many times.
It wouldn’t take much (ie: floorboard work) to get the A833 installed now.
If going with a stock 318 2-bbl – that will be a fun and usable combo. Maybe slightly more fun with a 2.94 or a 3.23 gears (or lower).
My ’77 wagon, with 3.23’s in it, a 904 (not 998 or 999) and 318 2-bbl, is rather fun to drive as is. Any more power and I wouldn’t get any traction (right at that limit - with current tires). It will hole shot most cars out there, as is – at least until I get to end of the intersection/stop light (when the engine runs out of steam).
With that said, I have no plans to modify my existing 318 2-bbl – for if I do, I will lose a lot of the fun factor it currently gives.
What will happen is to swap the low end power for mid/high end power – which without doing a whole lot more work won’t do much (you can only blow so much air through a soda straw). Overall, the car would be less fun to drive.
I would need to work in the compression ratio, camshaft, cylinder heads, intake and exhaust -
as a working combination to get more of what I want – and if I was going to do that, I might as well use a 360 with a stroker crankshaft (or precisely in my case, just drop in a stroker big block).
