- Joined
 - Apr 26, 2016
- Messages
 - 1,296
- Reaction score
 - 306
Thx BudFixed to say:
A500s are 2.74-1.54-1.00, same as A999s and some A998s
A518s are 2.45-1.45-1.00, same as A727s, A904s ,and some A998s
I had thought about doing this, more than a few times.
The only reason I'm not considering it is because the only thing connecting the bellhousing to the transmission case (as well as 500 HP/500 foot pounds of torque – or whatever it might actually be) is 6 (or 7, I forget) tiny screws that are ¼” in diameter.
I have twisted those front pump screw heads off before (it doesn't take much), during transmission overhauls - so I just don’t want that to be my “weak link”.
If there was a better way of attaching the bell to the case – then I would be driving one right now.
Also, I don't know of anyone personally using one - and in actuality, the 6 (or 7) tiny screws might be strong enough for my application – only I just don’t see how.
Actually, the transmission is the forward half of a 904 trans so the kick down rod will bolt right up and the shifter lickage too. The speedometer cable should reach, but a call to napa to get another. Since the rear gears are usually made more agressive like 410 or or my favorite 513, the speedometer gear needs changinging and that means another thread that has already been talked to. The plastic snap ring style cable on FMJ cars is limited on speedo gears, so go to a early mopar A body or E body speedo cable and aluminum cookie gear retainer housing.no neck snapping for this couple, I agree.
I'm assuming you have to adapt the size of the 'connecting rod' or whatever the term is for the rod that goes from the transmission to drive line? Oh Lord I should have done some reading so I'd sound like I know what I'm talking about...lol
This sounds like an interesting puzzle with potential for greatness when done. But its an awfully heavy part of the car and buried underneath. You'd really have to have a solid place to work on things and it would seem, a concentrated effort to stay organized with all the bits and pieces in play.
I bow to your persistence and knowledge as well as your courage to contemplate the project.
I should have included that the speedometer cable does not reach the new location (its in the overdrive housing on this transmission) I need to buy the 80' speedo cable, I'm using the GPS Speedo in my phone for the time being lolActually, the transmission is the forward half of a 904 trans so the kick down rod will bolt right up and the shifter lickage too. The speedometer cable should reach, but a call to napa to get another. Since the rear gears are usually made more agressive like 410 or or my favorite 513, the speedometer gear needs changinging and that means another thread that has already been talked to. The plastic snap ring style cable on FMJ cars is limited on speedo gears, so go to a early mopar A body or E body speedo cable and aluminum cookie gear retainer housing.
I'm using that 80 incher and it has a good amount of extra. I forgot how short the OE stuff isI should have included that the speedometer cable does not reach the new location (its in the overdrive housing on this transmission) I need to buy the 80' speedo cable, I'm using the GPS Speedo in my phone for the time being lol
Very nice!As far as tunnel modifications go I cut cross member completely out and replaced it with a section of box tube I formed to fit the tunnel. It pokes up above the floor a bit, but you can't tell with the carpet laying over it.
