Going Dana 60, so here it is: axle was originally out of a 1966 B body. 489 case with 4.10 gears and SG. The housing has had the perches cut off and rewelded 1/8" further out to match the factory F/J/M perch width. It was popular to take these axles and drop them in as is by forcing the springs inboard. I never liked that and had it done right. Comes with a pinion snubber and it complete drum to drum. The drums are OK, but will need new brakes. This axle will bolt right into place and is already setup for ISO delete.
Probably has 25k on it since the rebuild in 2007. It does howl a little under acceleration and has since new. The shop that put it together said something about new gear sets doing that. Feel free to pull it apart for inspection.
Will not ship. Make me a reasonable offer.
PM me here on the board. Located in Macomb Township, Michigan.
Figured I'd post here first as it's setup for F/J/M. If I don't get any bites I'll post it up on Moparts next.
