dytch2220
When I bought my car recently, the previous owner disclosed a few issues it had up front and I felt like they were ones I could solve on my own or with help diagnosing from a shop and then doing the work on my own. The main two were: 1) the car has a vibration that becomes pronounced between 55-65mph which seems to come from the front right wheel and 2) at hard acceleration the car hesitates until you feather off the gas then it begins to accelerate. I'm fairly certain the acceleration will be fixed by getting a new carb and it gives me a good excuse to move up to a 4 bbl rig. I've had the car to two shops, both of which gave up on figuring out the problem. One was the best alignment shop in my area, the other was a tires & service joint. Here is what they've tried or checked so far:
I just wanted to share what's going on with my car in the hopes that you all may have some other ideas of what to try next. Right now just waiting for my bigger payday in about a week so I can purchase a set of shocks all around.
- Loose bearing, front right. Tightened, no change.
- Rotated front right and left rear tires. No change.
- Checked brake rotors, no runout.
- Checked wheels, no runout.
- Replaced all 4 tires. No change. And thankfully they put my old tires back on after the test drive.
- Drive shaft, good to go.
- Suspension components, good to go.
